メインコンテンツにスキップ
Lenovo S20-30 Keyboard Replacement
必要な工具と部品
  1. Lenovo S20-30 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Flip the Lenovo S20-30 over so that the bottom panel is facing upward.
  2. Lenovo S20-30 Keyboard Replacement: 手順 2、 1の画像 1
    • Slide the manual battery latch to the unlock position, so that the red is showing.
  3. Lenovo S20-30 Keyboard Replacement: 手順 3、 2の画像 1 Lenovo S20-30 Keyboard Replacement: 手順 3、 2の画像 2
    • Slide and hold the spring-loaded battery latch on the other side (right) while sliding the battery out of the computer.
    • Grab new Lenovo S20-30 battery for replacement.
  4. Lenovo S20-30 Keyboard Replacement, Keyboard: 手順 4、 3の画像 1 Lenovo S20-30 Keyboard Replacement, Keyboard: 手順 4、 3の画像 2 Lenovo S20-30 Keyboard Replacement, Keyboard: 手順 4、 3の画像 3
    • Remove the two front rubber feet using a long metal spudger.
    • Use your Phillips #0 screwdriver to remove the two M2.5 x 5mm flat-head screws located underneath the pads.
  5. Lenovo S20-30 Keyboard Replacement: 手順 5、 1の画像 1
    • Use the Phillips #0 screwdriver to remove the nine M2 x 4mm flat head screws located on the outer edges on the back of the laptop.
    • Make sure to keep these screws separated from future screws that will be disassembled throughout this process.
  6. Lenovo S20-30 Keyboard Replacement: 手順 6、 2の画像 1 Lenovo S20-30 Keyboard Replacement: 手順 6、 2の画像 2
    • Use the long metal spudger to pry open the bottom half of the laptop.
    • Gently lift the cover off to reveal the motherboard.
  7. Lenovo S20-30 Keyboard Replacement: 手順 7、 2の画像 1 Lenovo S20-30 Keyboard Replacement: 手順 7、 2の画像 2
    • Remove the four M2 x 3mm flat-head screw using a Phillips #000 screwdriver.
  8. Lenovo S20-30 Keyboard Replacement: 手順 8、 2の画像 1 Lenovo S20-30 Keyboard Replacement: 手順 8、 2の画像 2
    • Flip over laptop and open the lid to have access to the keyboard.
    • Use a plastic opening tool to pry apart the keyboard.
  9. Lenovo S20-30 Keyboard Replacement: 手順 9、 3の画像 1 Lenovo S20-30 Keyboard Replacement: 手順 9、 3の画像 2 Lenovo S20-30 Keyboard Replacement: 手順 9、 3の画像 3
    • A connector is attached to the keyboard.
    • Remove it by gently pulling it outward.
  10. Lenovo S20-30 Keyboard Replacement: 手順 10、 1の画像 1
    • Grab replacement keyboard to insert back into place.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
ILEANISSE SOTO
メンバー登録日: 10/01/18
187 ポイント
1ガイドが承認済み
チーム
McKendree University, Team S1-G4, Quinn Fall 2018 McKendree University, Team S1-G4, Quinn Fall 2018人のメンバー
MCKU-QUINN-F18S1G4
2 メンバー
3のガイドは作成済み
コメント 1 件
where can i find a replacement keyboard/ or what model # do i need?
ed paz - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 13
今までの合計 1,217
