メインコンテンツにスキップ
Lenovo N23 Chromebook Battery Replacement
必要な工具と部品
  1. Lenovo N23 Chromebook Battery Replacement, Battery: 手順 1、 2の画像 1 Lenovo N23 Chromebook Battery Replacement, Battery: 手順 1、 2の画像 2
    • Before starting, make sure that the laptop is powered off and completely unplugged from the charger.
    • Remove the eight 6.0 mm screws holding the back into place using a Phillips #0 screwdriver.
  2. Lenovo N23 Chromebook Battery Replacement: 手順 2、 1の画像 1
    • Flip the device over.
    • Slide a plastic opening tool between the back cover and keyboard.
    • Carefully pry upwards until you hear a click.
    • Following the seam, slide the opening tool all the way around the front cover, prying upwards occasionally until the keyboard and trackpad are loose from the back cover.
    • Lift the keyboard panel up to reveal the internals.
    • Don't lift the keyboard panel too violently, as there is still a cable attachment to the motherboard.
  3. Lenovo N23 Chromebook Battery Replacement: 手順 3、 3の画像 1 Lenovo N23 Chromebook Battery Replacement: 手順 3、 3の画像 2 Lenovo N23 Chromebook Battery Replacement: 手順 3、 3の画像 3
    • You can now access the internals of the computer.
    • Disconnect the two ribbon cables that connect from the motherboard to the front cover.
    • Using the iFixit opening tool, flip up the black tab holding keyboard ribbon cable and then pull the cable out.
    • Using the opening tool, flip the white tab holding the mouse ribbon cable and then pull the cable out.
  4. Lenovo N23 Chromebook Battery Replacement: 手順 4、 2の画像 1 Lenovo N23 Chromebook Battery Replacement: 手順 4、 2の画像 2
    • Lift the keyboard panel from the case and fully remove it from the device.
  5. Lenovo N23 Chromebook Battery Replacement: 手順 5、 1の画像 1
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the battery in place.
  6. Lenovo N23 Chromebook Battery Replacement: 手順 6、 3の画像 1 Lenovo N23 Chromebook Battery Replacement: 手順 6、 3の画像 2 Lenovo N23 Chromebook Battery Replacement: 手順 6、 3の画像 3
    • Disconnect the battery cable using a plastic opening tool by pulling on the black plastic lip.
    • Lift the battery out of the laptop.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Jarod Ostir
メンバー登録日: 02/19/21
465 ポイント
3のガイドは作成済み
チーム
University of Alabama, Team S3-G1, Bedsole Spring 2021 University of Alabama, Team S3-G1, Bedsole Spring 2021人のメンバー
UA-BEDSOLE-S21S3G1
3 メンバー
4のガイドは作成済み
コメント 1 件
What happens, say the thing is barely alive and partially destroyed, if the battery is bent? i want save as many parts as posible
Wyatt Smith - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 32
今までの合計 797
