メインコンテンツにスキップ
Lenovo N22 Chromebook Wireless Card Replacement
必要な工具と部品
  1. Lenovo N22 Chromebook Wireless Card Replacement, Keyboard: 手順 1、 3の画像 1 Lenovo N22 Chromebook Wireless Card Replacement, Keyboard: 手順 1、 3の画像 2 Lenovo N22 Chromebook Wireless Card Replacement, Keyboard: 手順 1、 3の画像 3
    • Power down the Chromebook before starting the repair.
    • Opening the Chromebook voids the manufacturer warranty.
    • Flip the Chromebook so that the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
    • Use a spudger to remove each of the 4 rubber feet.
    • Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
  2. Lenovo N22 Chromebook Wireless Card Replacement: 手順 2、 3の画像 1 Lenovo N22 Chromebook Wireless Card Replacement: 手順 2、 3の画像 2 Lenovo N22 Chromebook Wireless Card Replacement: 手順 2、 3の画像 3
    • Flip the Chromebook back over and open the screen.
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
    • Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
    • It is normal for the tabs to make a loud click when released. The corner tabs will be harder to release than the others and will make a louder click.
  3. Lenovo N22 Chromebook Wireless Card Replacement: 手順 3、 2の画像 1 Lenovo N22 Chromebook Wireless Card Replacement: 手順 3、 2の画像 2
    • Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
    • Do not lift the keyboard quickly or you might break the two cables that connect the keyboard to the motherboard.
    • Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
    • Slowly pull the cables up and out of the connectors.
  4. Lenovo N22 Chromebook Wireless Card Replacement: 手順 4、 1の画像 1
    • Lift the keyboard up and off the back panel, exposing the motherboard and battery.
  5. Lenovo N22 Chromebook Wireless Card Replacement, Wireless Card: 手順 5、 2の画像 1 Lenovo N22 Chromebook Wireless Card Replacement, Wireless Card: 手順 5、 2の画像 2
    • Use a Philips #1 screwdriver to remove the 3.6 mm screw from the back panel.
  6. Lenovo N22 Chromebook Wireless Card Replacement: 手順 6、 1の画像 1
    • Gently slide the wireless card to the right to remove it from the standard socket on the motherboard.
  7. Lenovo N22 Chromebook Wireless Card Replacement: 手順 7、 2の画像 1 Lenovo N22 Chromebook Wireless Card Replacement: 手順 7、 2の画像 2
    • Grab the black and white wires as close to the antenna cable connectors as possible.
    • Gently pull the black and white wires away from the antenna cable connectors on the wireless card.
    • When reinstalling, place the wires on the antenna cable connectors and gently press straight down. The wires should snap back into the connector.
    • When reinstalling, make sure that the white wire and the black wire are put back in their original connectors.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Megan Louie
メンバー登録日: 04/26/17
323 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S21-G1, Livingston Spring 2017 Cal Poly, Team S21-G1, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S21G1
4 メンバー
14のガイドは作成済み
コメント 1 件
Very well explained and photographed. My first attempt at a laptop repair and this guide made it possible.
Thanks!
Jeff Koskela - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 33
今までの合計 4,212
