メインコンテンツにスキップ
Lenovo N22 Chromebook Individual Key Replacement
必要な工具と部品
  1. Lenovo N22 Chromebook Individual Key Replacement, Individual Key: 手順 1、 1の画像 1
    • Power down the chromebook before starting this process.
    • Loosen the key by prying on the edge of the key with the plastic opening tool.
  2. Lenovo N22 Chromebook Individual Key Replacement: 手順 2、 2の画像 1 Lenovo N22 Chromebook Individual Key Replacement: 手順 2、 2の画像 2
    • Remove the key from the keyboard by prying the key off with the opener or with your finger.
    • The key is connected to the keyboard with two connecting plastic squares. One is connected to the keyboard by tabs and one is connected to the keyboard by snaps.
    • When reassembling make sure that the two plastic square connectors are in the same place as when you removed the key.
終わりに
13 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jackson Tucker
メンバー登録日: 04/26/17
869 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S21-G1, Livingston Spring 2017 Cal Poly, Team S21-G1, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S21G1
4 メンバー
14のガイドは作成済み
6 件のコメント
very vague info. If a Key does not work and I take it out, why should it work once back in?? what do I need to change or look for? seems like very good instructions to take the keys out of a notebook
edperalt - 返信
Where can I order individual keys?
Mallory Montreuil - 返信
He tried to turn it on but it did not work
Clayton Sensing - 返信
I took it off and now it broken he he
BRENNEN FIRKUS - 返信
Yeah so I tried this on my computer to clean my keys and now my alt key won’t go back in. I also got my g key partially stuck in so only the right side of it works. Is there anything I am supposed to do?
Anushka Halepet - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 20
過去 30 日: 83
今までの合計 14,380
