メインコンテンツにスキップ
Lenovo Legion Y7000P Back Cover Replacement
必要な工具と部品
  1. Lenovo Legion Y7000P Back Cover Replacement, Flip your laptop over: 手順 1、 1の画像 1
    • Flip your laptop over so the rubber feet are facing up.
  2. Lenovo Legion Y7000P Back Cover Replacement, Unfasten the back cover: 手順 2、 2の画像 1 Lenovo Legion Y7000P Back Cover Replacement, Unfasten the back cover: 手順 2、 2の画像 2
    • Use a Phillips screwdriver to remove the 11 screws securing the back cover:
    • Five 11.5 mm‑long screws
    • Six 4.7 mm-long screws
  3. Lenovo Legion Y7000P Back Cover Replacement, Insert an opening pick: 手順 3、 2の画像 1 Lenovo Legion Y7000P Back Cover Replacement, Insert an opening pick: 手順 3、 2の画像 2
    • Insert the flat side of an opening pick between the top right corner of the back cover and frame.
  4. Lenovo Legion Y7000P Back Cover Replacement, Release the back cover's clips: 手順 4、 3の画像 1 Lenovo Legion Y7000P Back Cover Replacement, Release the back cover's clips: 手順 4、 3の画像 2 Lenovo Legion Y7000P Back Cover Replacement, Release the back cover's clips: 手順 4、 3の画像 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
    • Keep the pick angled upwards while sliding to help release the clips.
    • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
  5. Lenovo Legion Y7000P Back Cover Replacement: 手順 5、 3の画像 1 Lenovo Legion Y7000P Back Cover Replacement: 手順 5、 3の画像 2 Lenovo Legion Y7000P Back Cover Replacement: 手順 5、 3の画像 3
    • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
  6. Lenovo Legion Y7000P Back Cover Replacement, Remove the back cover: 手順 6、 3の画像 1 Lenovo Legion Y7000P Back Cover Replacement, Remove the back cover: 手順 6、 3の画像 2 Lenovo Legion Y7000P Back Cover Replacement, Remove the back cover: 手順 6、 3の画像 3
    • Remove the back cover.
  7. Lenovo Legion Y7000P Back Cover Replacement, Reassembly information: 手順 7、 3の画像 1 Lenovo Legion Y7000P Back Cover Replacement, Reassembly information: 手順 7、 3の画像 2 Lenovo Legion Y7000P Back Cover Replacement, Reassembly information: 手順 7、 3の画像 3
    • During reassembly:
    • Slide the two tabs near the center of the back cover's top edge under the hinge cover.
    • Press down firmly around the perimeter of the back cover to engage all the clips.
終わりに
作成者
2人の作成者と共同で作成されました。
Spencer Day
メンバー登録日: 09/14/22
55,203 ポイント
408のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,430のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 13
今までの合計 140
