メインコンテンツにスキップ
Lenovo Legion Y530-15ICH Wireless LAN Card Replacement
必要な工具と部品
  1. Lenovo Legion Y530-15ICH Wireless LAN Card Replacement, Wireless LAN Card: 手順 1、 1の画像 1
    • Make sure your computer is turned off.
    • Remove the five 7 mm screws using a Phillips #0 screwdriver.
    • Remove the six 4 mm screws using a Phillips #0 screwdriver.
  2. Lenovo Legion Y530-15ICH Wireless LAN Card Replacement: 手順 2、 1の画像 1
    • Slowly and carefully pry off the backside of the computer using an opening pick.
    • You can start from the corner or sides of computer. Slowly work around the computer until it completely detaches.
  3. Lenovo Legion Y530-15ICH Wireless LAN Card Replacement: 手順 3、 1の画像 1
    • Detach the two antenna wires attached to the wireless LAN card.
  4. Lenovo Legion Y530-15ICH Wireless LAN Card Replacement: 手順 4、 1の画像 1
    • Remove the single 4 mm screw using a Phillips #0 screwdriver.
    • Remove the wireless LAN card.
  5. Lenovo Legion Y530-15ICH Wireless LAN Card Replacement: 手順 5、 1の画像 1
    • Insert the new wireless LAN card.
    • Re-insert the 4 mm screw using Phillips #0 screwdriver.
    • It's normal for the wireless LAN card to pop up slightly. It will fit into place when you screw it back in.
  6. Lenovo Legion Y530-15ICH Wireless LAN Card Replacement: 手順 6、 1の画像 1
    • Re-attach the black antenna cable to the top pin on the wireless LAN card.
    • Re-attach the white antenna cable to the bottom pin on the wireless LAN card.
  7. Lenovo Legion Y530-15ICH Wireless LAN Card Replacement: 手順 7、 1の画像 1
    • Snap the back cover onto the laptop.
    • Using a Phillips #0 screwdriver, re-insert the five 7mm screws.
    • Using a Phillips #0 screwdriver, re-insert the six 4mm screws.
終わりに
After replacing the faulty wireless LAN card, you should be able to connect to a wireless network connection. The connection should be stable and not randomly disconnecting. If this doesn’t fix your problem, then you may have to check the router or wireless connection point.
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Christopher Nguyen
メンバー登録日: 09/19/20
199 ポイント
1ガイドが承認済み
チーム
York University, Team S2-G18, Melo-Thaiss Fall 2020 York University, Team S2-G18, Melo-Thaiss Fall 2020人のメンバー
YORK-MELO-THAISS-F20S2G18
1 メンバー
1のガイドは作成済み
1件のガイドコメント
Great guide! I would like to note that when removing the bottom panel some of the seam, especially around the side vents, can be a little hard to find as the seam follows the vent from the bottom to the top. I started prying at the front and then moved to the back, and then to the vent areas on the sides last. That helped make getting the pick in around the vents easier.
ingow - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 25
今までの合計 2,203
