はじめに
Most of these laptops were shipped with a trash wifi card that disconnects constantly. The Realtek 8822BE. That’s probably why you are here. Don’t worry, it’s simple to remove and replace.
必要な工具と部品
Remove the 5 long and 6 short Phillips head screws on the back of the computer (I am missing one). They are located around the perimeter of the bottom as well as one in the center of the fan grille. Take off the back cover.
Remove the connections to the antenna for the card. On my Realtek 8822BE model they are white and black. Yours may be a different color but the process is identical
Use the same Phillips driver you used to open the case and unscrew the card. Be careful.
Pull gently and the card will remove. To put in a new card just repeat these steps in reverse.
To reassemble your device, follow these instructions in reverse order. Be sure to keep your hands dry and be careful with electronics.
ある他の人がこのガイドを完成しました。
4件のガイドコメント
which alternative do you recommend?
Mine lenovo Legion Y530-15ICH not boots with new AX211NGW
Is there any restriction in BIOS for Wifi Card Replacement?
for Lenovo Legion Y530-15ICH Laptop, serial: PF1JD34B
