メインコンテンツにスキップ
Lenovo Legion Y530-15ICH Hard Drive Replacement
必要な工具と部品
  1. Lenovo Legion Y530-15ICH Hard Drive Replacement, External screws: 手順 1、 1の画像 1
    • Shut down the computer and disconnect the power supply.
    • Using a PH1 screwdriver or bit, remove eleven screws securing the back cover.
    • Five 7mm screws
    • Two 6mm screws
    • Four 4mm screws
  2. Lenovo Legion Y530-15ICH Hard Drive Replacement, Rear enclosure: 手順 2、 2の画像 1 Lenovo Legion Y530-15ICH Hard Drive Replacement, Rear enclosure: 手順 2、 2の画像 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at one of the rear corners of the laptop and work your way around the chassis, gently pulling up on the cover until it detaches.
    • Do not pull hard on the cover or attempt to open without picks, as I did, cracking the side of the rear cover.
  3. Lenovo Legion Y530-15ICH Hard Drive Replacement: 手順 3、 2の画像 1 Lenovo Legion Y530-15ICH Hard Drive Replacement: 手順 3、 2の画像 2
    • Remove four screws from the HDD case, mostly releasing it from the laptop.
    • Four 4mm screws
    • You might see a yellow piece of tape here. Peel it off carefully, right to left in this orientation, so that the blue plastic of the ribbon cable beneath is unmoved when it's gone.
  4. Lenovo Legion Y530-15ICH Hard Drive Replacement: 手順 4、 2の画像 1 Lenovo Legion Y530-15ICH Hard Drive Replacement: 手順 4、 2の画像 2
    • Use your prying tool or a spudger to flip up the FFC bail, the tiny black clamp shown here.
    • If the cable doesn't move freely after the bail is up, make sure it's pushed all the way back, and lightly tug the cable away from its clamp.
    • Pull only parallel to the board, and only after the bail is up.
  5. Lenovo Legion Y530-15ICH Hard Drive Replacement: 手順 5、 1の画像 1
    • Once the screws are gone and the ribbon cable is safely disconnected, remove the hard drive with the casing from the rest of the computer.
    • Remove four screws from the casing, releasing the hard drive.
    • Four 3.5mm screws
  6. Lenovo Legion Y530-15ICH Hard Drive Replacement: 手順 6、 1の画像 1
    • Remove the hard drive from the casing.
  7. Lenovo Legion Y530-15ICH Hard Drive Replacement: 手順 7、 2の画像 1 Lenovo Legion Y530-15ICH Hard Drive Replacement: 手順 7、 2の画像 2
    • This piece connects your hard drive to the computer. Remove it carefully, wiggling back and forth. Replace it on your new hard drive.
終わりに
Once the ribbon cable piece has been attached to the new hard drive, just follow these steps in the reverse order.
作成者
1人の作成者と共同作成されました。
Isak
メンバー登録日: 08/30/24
252 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 38
今までの合計 357
