メインコンテンツにスキップ
Lenovo Legion Y520-15IKBN Hard Drive Replacement
必要な工具と部品
  1. Lenovo Legion Y520-15IKBN Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 1 Lenovo Legion Y520-15IKBN Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 2
    • Remove the thirteen 6.5 mm screws from the bottom of the laptop using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Hard Drive Replacement: 手順 2、 1の画像 1
    • Flip the laptop on its side and use a spudger or a credit card to pry the bottom covering off. To get a better grip you may want to open the laptop slightly.
    • The bottom piece will make popping noises as it is pulled from the laptop.
    • When reassembling make sure that the bottom piece clicks back into place on all sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Hard Drive Replacement: 手順 3、 3の画像 1 Lenovo Legion Y520-15IKBN Hard Drive Replacement: 手順 3、 3の画像 2 Lenovo Legion Y520-15IKBN Hard Drive Replacement: 手順 3、 3の画像 3
    • The hard drive is a white square located on the right side of your device.
    • Use a Phillips #00 screwdriver to remove four 4.0 mm screws holding the hard drive in place.
  4. Lenovo Legion Y520-15IKBN Hard Drive Replacement: 手順 4、 2の画像 1 Lenovo Legion Y520-15IKBN Hard Drive Replacement: 手順 4、 2の画像 2
    • Slide the hard drive from the device towards your right.
    • When reinstalling remember to slide the hard drive in from the right. Don't try to force it in from the front.
終わりに
8 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Naomi Williams
メンバー登録日: 10/04/18
771 ポイント
2のガイドは作成済み
チーム
Linn Benton Community College, Team S1-G2, Karnes Fall 2018 Linn Benton Community College, Team S1-G2, Karnes Fall 2018人のメンバー
LBCC-KARNES-F18S1G2
4 メンバー
17のガイドは作成済み
コメント 1 件
Hi,
does anyone know if replacing the 1TB hard disk with a 1TB SSD is possible? (I’m thinking in terms of cloning the whole disk: can I go for a 1TB SSD or do I need a bigger one? Do hidden partitions for restoring the system / this kind of stuff get copied correctly? Most tutorials online just copy the Windows partition: wouldn’t want to find out I can’t reset the system if needed.)
Cycy - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 27
過去 30 日: 100
今までの合計 11,325
