メインコンテンツにスキップ
Lenovo Ideatab S6000 Speakers Replacement
必要な工具と部品
  1. Lenovo Ideatab S6000 Speakers Replacement, Battery: 手順 1、 1の画像 1
    • Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a craft knife.
    • These screens are held in place by glue that is hard to remove. Please take your time to ensure that that this step is done correctly.
  2. Lenovo Ideatab S6000 Speakers Replacement: 手順 2、 1の画像 1
    • Remove the screws from both of the spots that were covered.
  3. Lenovo Ideatab S6000 Speakers Replacement: 手順 3、 1の画像 1
    • DO NOT USE A METAL TOOL FOR THIS.
    • Go all around the casing, prying the screen away from the backing with the spudger.
    • It will make a popping sound each time one of the lock tabs is disconnected.
    • Take your time as you move all around the device when prying the backing off.
  4. Lenovo Ideatab S6000 Speakers Replacement: 手順 4、 1の画像 1
    • Pull off the plastic that is covering the battery cable.
  5. Lenovo Ideatab S6000 Speakers Replacement: 手順 5、 2の画像 1 Lenovo Ideatab S6000 Speakers Replacement: 手順 5、 2の画像 2
    • Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it.
  6. Lenovo Ideatab S6000 Speakers Replacement: 手順 6、 1の画像 1
    • Remove the battery by grabbing the tab shown and pulling up.
    • The battery is held to the device by adhesive. Pull the battery up from the tab and it will lift out with a bit of effort.
  7. Lenovo Ideatab S6000 Speakers Replacement, Speakers: 手順 7、 3の画像 1 Lenovo Ideatab S6000 Speakers Replacement, Speakers: 手順 7、 3の画像 2 Lenovo Ideatab S6000 Speakers Replacement, Speakers: 手順 7、 3の画像 3
    • The speakers are connected to the tablet by glue and require a lot of prying to remove.
    • Make sure to get all the way under the speakers when prying.
  8. Lenovo Ideatab S6000 Speakers Replacement: 手順 8、 2の画像 1 Lenovo Ideatab S6000 Speakers Replacement: 手順 8、 2の画像 2
    • This step is not necessary if you aren't replacing the speakers.
    • To the remove the wires heat the solder connecting the wires to the board, and gently pull on the wires.
    • Remember the placement of the red and black wires.
    • Connect new speakers by soldering the wires onto the board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Josiah Speed
メンバー登録日: 09/22/14
965 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 10-4, Brown Fall 2014 USF Tampa, Team 10-4, Brown Fall 2014人のメンバー
USFT-BROWN-F14S10G4
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 625
