はじめに
This guide shows a step by step process to replace the screen on a Lenovo Ideatab S6000. The part being replaced is the screen and the digitizer. They are both included in one assembly. This part would need to be replaced if the display is not working properly or the touch screen display is faulty. If the screen is cracked or shattered, be sure to wear proper protective equipment and make sure device is turned off before any repair is started.
必要な工具と部品
ある他の人がこのガイドを完成しました。
