メインコンテンツにスキップ
Lenovo Ideapad Yoga 2 11 Battery Replacement
必要な工具と部品
  1. Lenovo Ideapad Yoga 2 11 Battery Replacement, Back Panel: 手順 1、 1の画像 1
    • Begin by turning your closed laptop so that you are looking at the bottom panel.
  2. Lenovo Ideapad Yoga 2 11 Battery Replacement: 手順 2、 2の画像 1 Lenovo Ideapad Yoga 2 11 Battery Replacement: 手順 2、 2の画像 2
    • Locate the 10 screws (6mm) around the border of the panel.
    • Using the Torx T5 Screwdriver, remove the screws.
  3. Lenovo Ideapad Yoga 2 11 Battery Replacement: 手順 3、 1の画像 1
    • Now that the screws are removed, gently lift the back panel upwards to detach it from the rest of your laptop.
  4. Lenovo Ideapad Yoga 2 11 Battery Replacement, Battery: 手順 4、 2の画像 1 Lenovo Ideapad Yoga 2 11 Battery Replacement, Battery: 手順 4、 2の画像 2
    • Locate the battery in the bottom right corner.
    • Using a Phillips #000, remove the 6 screws (3.5mm) on the border of the battery and the 7th screw (6.5mm) that is in the center of the battery.
  5. Lenovo Ideapad Yoga 2 11 Battery Replacement: 手順 5、 3の画像 1 Lenovo Ideapad Yoga 2 11 Battery Replacement: 手順 5、 3の画像 2 Lenovo Ideapad Yoga 2 11 Battery Replacement: 手順 5、 3の画像 3
    この手順で使用する道具:
    購入する
    • Locate the cable connecting to the battery. It is located at the top-center of the battery.
    • Use a pair of tweezers and place it so that the tweezer is around the cables. Gently pull the cables towards the battery to disconnect the cable.
  6. Lenovo Ideapad Yoga 2 11 Battery Replacement: 手順 6、 2の画像 1 Lenovo Ideapad Yoga 2 11 Battery Replacement: 手順 6、 2の画像 2
    • There may be tape around the edge of the battery to secure some wires. Use a pair of tweezers to remove the tape so that the wires are no longer attached to the battery.
  7. Lenovo Ideapad Yoga 2 11 Battery Replacement: 手順 7、 2の画像 1 Lenovo Ideapad Yoga 2 11 Battery Replacement: 手順 7、 2の画像 2
    • After you have unscrewed the screws, unplugged the cable, and removed the tape and wires, you can remove the battery from your laptop.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Andria Chen
メンバー登録日: 10/17/17
624 ポイント
5のガイドは作成済み
チーム
UC Santa Barbara, Team S1-G5, Weedon Fall 2017 UC Santa Barbara, Team S1-G5, Weedon Fall 2017人のメンバー
UCSB-WEEDON-F17S1G5
5 メンバー
5のガイドは作成済み
コメント 1 件
Excellent instructions makes it easy even for novice
bhimanagouda patil - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 1,815
