メインコンテンツにスキップ
Lenovo Ideapad S415 Touch Hard Drive Replacement
必要な工具と部品
  1. Lenovo Ideapad S415 Touch Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch Hard Drive Replacement: 手順 2、 1の画像 1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch Hard Drive Replacement: 手順 3、 1の画像 1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch Hard Drive Replacement: 手順 4、 1の画像 1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch Hard Drive Replacement: 手順 5、 1の画像 1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch Hard Drive Replacement, Hard Drive: 手順 6、 2の画像 1 Lenovo Ideapad S415 Touch Hard Drive Replacement, Hard Drive: 手順 6、 2の画像 2
    • Locate the five black screws on the back.
    • Use a Phillips #0 screwdriver to remove all five black 6 mm screws.
  7. Lenovo Ideapad S415 Touch Hard Drive Replacement: 手順 7、 2の画像 1 Lenovo Ideapad S415 Touch Hard Drive Replacement: 手順 7、 2の画像 2
    • Locate the three silver screws underneath the battery.
    • Use the Phillips #0 screwdriver to remove all three 4 mm screws.
  8. Lenovo Ideapad S415 Touch Hard Drive Replacement: 手順 8、 3の画像 1 Lenovo Ideapad S415 Touch Hard Drive Replacement: 手順 8、 3の画像 2 Lenovo Ideapad S415 Touch Hard Drive Replacement: 手順 8、 3の画像 3
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stopper with your hands.
    • Use the Phillips #0 screwdriver to remove the 6 mm screws underneath all four stoppers.
  9. Lenovo Ideapad S415 Touch Hard Drive Replacement: 手順 9、 1の画像 1
    • Open the laptop carefully.
  10. Lenovo Ideapad S415 Touch Hard Drive Replacement: 手順 10、 2の画像 1 Lenovo Ideapad S415 Touch Hard Drive Replacement: 手順 10、 2の画像 2
    • Locate the hard drive.
    • Use the Phillips #0 screwdriver to remove the two 4 mm screws that are holding the hard drive in place.
  11. Lenovo Ideapad S415 Touch Hard Drive Replacement: 手順 11、 1の画像 1
    • The hard drive is now removed from the laptop.
  12. Lenovo Ideapad S415 Touch Hard Drive Replacement: 手順 12、 2の画像 1 Lenovo Ideapad S415 Touch Hard Drive Replacement: 手順 12、 2の画像 2
    • Once the hard drive is removed, locate the four screws that hold the metal frame to the hard drive.
    • Use the Phillips #0 screwdriver to remove the 4 mm silver screws on all sides.
終わりに
作成者
3人の作成者と共同で作成されました。
Casey Zhang
メンバー登録日: 02/06/19
315 ポイント
2のガイドは作成済み
チーム
UC Davis, Team S20-G5, Lore Winter 2019 UC Davis, Team S20-G5, Lore Winter 2019人のメンバー
UCD-LORE-W19S20G5
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 549
