メインコンテンツにスキップ
Lenovo Ideapad Flex 4-1570 Display Replacement
必要な工具と部品
  1. Lenovo Ideapad Flex 4-1570 Display Replacement, Back Panel: 手順 1、 1の画像 1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Display Replacement: 手順 2、 1の画像 1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Display Replacement: 手順 3、 1の画像 1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Display Replacement, Display: 手順 4、 2の画像 1 Lenovo Ideapad Flex 4-1570 Display Replacement, Display: 手順 4、 2の画像 2
    • Use an opening tool to remove the three hinge bezels.
  5. Lenovo Ideapad Flex 4-1570 Display Replacement: 手順 5、 1の画像 1
    • Remove the four 4 mm screws (two on each hinge) using a T5 Torx screwdriver.
  6. Lenovo Ideapad Flex 4-1570 Display Replacement: 手順 6、 3の画像 1 Lenovo Ideapad Flex 4-1570 Display Replacement: 手順 6、 3の画像 2 Lenovo Ideapad Flex 4-1570 Display Replacement: 手順 6、 3の画像 3
    • Attach a suction handle to the corner of the display, then wedge the blade of a Jimmy between the display and its housing.
    • While sliding the Jimmy around the perimeter, place opening picks in the gap you created at regular intervals.
    • Once you've worked around the perimeter, lightly pull on the suction handle while gently prying with an opening tool until the display releases.
  7. Lenovo Ideapad Flex 4-1570 Display Replacement: 手順 7、 1の画像 1
    • Use a T5 Torx screwdriver to remove the six 4 mm screws (three on each hinge) securing the hinges.
  8. Lenovo Ideapad Flex 4-1570 Display Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use tweezers to remove the rubber stoppers in both hinges.
  9. Lenovo Ideapad Flex 4-1570 Display Replacement: 手順 9、 1の画像 1
    • Remove the black foam over the black and white cords, to the left of the Wi-Fi card, using tweezers.
  10. Lenovo Ideapad Flex 4-1570 Display Replacement: 手順 10、 1の画像 1
    • Disconnect the black cable near the fan using tweezers.
  11. Lenovo Ideapad Flex 4-1570 Display Replacement: 手順 11、 1の画像 1
    • Remove the display from the rest of the computer.
終わりに
作成者
3人の作成者と共同で作成されました。
Hunter Page
メンバー登録日: 02/13/22
157 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 4
過去 30 日: 20
今までの合計 277
