メインコンテンツにスキップ
Lenovo Ideapad Flex 15 Speaker Replacement
必要な工具と部品
  1. Lenovo Ideapad Flex 15 Speaker Replacement, Bottom Panel: 手順 1、 2の画像 1 Lenovo Ideapad Flex 15 Speaker Replacement, Bottom Panel: 手順 1、 2の画像 2
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 Speaker Replacement: 手順 2、 2の画像 1 Lenovo Ideapad Flex 15 Speaker Replacement: 手順 2、 2の画像 2
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 Speaker Replacement: 手順 3、 3の画像 1 Lenovo Ideapad Flex 15 Speaker Replacement: 手順 3、 3の画像 2 Lenovo Ideapad Flex 15 Speaker Replacement: 手順 3、 3の画像 3
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 Speaker Replacement: 手順 4、 1の画像 1
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 Speaker Replacement: 手順 5、 3の画像 1 Lenovo Ideapad Flex 15 Speaker Replacement: 手順 5、 3の画像 2 Lenovo Ideapad Flex 15 Speaker Replacement: 手順 5、 3の画像 3
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 Speaker Replacement: 手順 6、 2の画像 1 Lenovo Ideapad Flex 15 Speaker Replacement: 手順 6、 2の画像 2
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
  7. Lenovo Ideapad Flex 15 Speaker Replacement, Speaker: 手順 7、 3の画像 1 Lenovo Ideapad Flex 15 Speaker Replacement, Speaker: 手順 7、 3の画像 2 Lenovo Ideapad Flex 15 Speaker Replacement, Speaker: 手順 7、 3の画像 3
    • Locate the speaker unit at the top left hand corner of the Flex 15.
    • Using the screwdriver (PH1 bit), remove the (50 mm) screws on either side of the speaker unit.
  8. Lenovo Ideapad Flex 15 Speaker Replacement: 手順 8、 2の画像 1 Lenovo Ideapad Flex 15 Speaker Replacement: 手順 8、 2の画像 2
    • There is a small white socket which a cable of the speakers is plugged into.
    • Pull the wire off by pulling either sides of the black header (do not pull the wire directly as it could break off).
    • The speaker can be removed carefully.
終わりに
作成者
4人の作成者と共同で作成されました。
Brent
メンバー登録日: 03/04/16
804 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 6-6, Bhusal Spring 2016 UMass Dartmouth, Team 6-6, Bhusal Spring 2016人のメンバー
UMASSD-BHUSAL-S16S6G6
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 7
今までの合計 1,058
