メインコンテンツにスキップ
Lenovo Ideapad Flex 15 Hard Drive Replacement
必要な工具と部品
  1. Lenovo Ideapad Flex 15 Hard Drive Replacement, Bottom Panel: 手順 1、 2の画像 1 Lenovo Ideapad Flex 15 Hard Drive Replacement, Bottom Panel: 手順 1、 2の画像 2
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 2、 2の画像 1 Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 2、 2の画像 2
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 3、 3の画像 1 Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 3、 3の画像 2 Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 3、 3の画像 3
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 4、 1の画像 1
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 5、 3の画像 1 Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 5、 3の画像 2 Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 5、 3の画像 3
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 6、 2の画像 1 Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 6、 2の画像 2
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
  7. Lenovo Ideapad Flex 15 Hard Drive Replacement, Hard Drive: 手順 7、 1の画像 1
    • Locate the hard drive assembly on the top right hand corner of the Flex 15 based on the orientation of the device in the picture.
  8. Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 8、 3の画像 1 Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 8、 3の画像 2 Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 8、 3の画像 3
    • Begin by unscrewing the four (20 mm) black screws that surround the hard drive’s metal cage.
    • Once removed, remove the black SATA connector by pulling it from the hard drive unit towards the right hand side of the laptop.
  9. Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 9、 3の画像 1 Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 9、 3の画像 2 Lenovo Ideapad Flex 15 Hard Drive Replacement: 手順 9、 3の画像 3
    • The hard drive should be freed from the base of the laptop.
    • There are four (20 mm) black screws surrounding the hard drive from the cage. Unscrew these to free the hard drive from the cage
終わりに
6 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Brent
メンバー登録日: 03/04/16
804 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 6-6, Bhusal Spring 2016 UMass Dartmouth, Team 6-6, Bhusal Spring 2016人のメンバー
UMASSD-BHUSAL-S16S6G6
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 10
過去 30 日: 28
今までの合計 6,935
