メインコンテンツにスキップ
Lenovo Ideapad 320-17IKB Heat Sink Replacement
必要な工具と部品
  1. Lenovo Ideapad 320-17IKB Heat Sink Replacement, Back Panel: 手順 1、 1の画像 1
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
  2. Lenovo Ideapad 320-17IKB Heat Sink Replacement: 手順 2、 2の画像 1 Lenovo Ideapad 320-17IKB Heat Sink Replacement: 手順 2、 2の画像 2
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
  3. Lenovo Ideapad 320-17IKB Heat Sink Replacement: 手順 3、 1の画像 1
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
  4. Lenovo Ideapad 320-17IKB Heat Sink Replacement: 手順 4、 2の画像 1 Lenovo Ideapad 320-17IKB Heat Sink Replacement: 手順 4、 2の画像 2
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
  5. Lenovo Ideapad 320-17IKB Heat Sink Replacement, Battery: 手順 5、 2の画像 1 Lenovo Ideapad 320-17IKB Heat Sink Replacement, Battery: 手順 5、 2の画像 2
    • Remove five 7mm Phillips #0 screws from the battery holder.
  6. Lenovo Ideapad 320-17IKB Heat Sink Replacement: 手順 6、 2の画像 1 Lenovo Ideapad 320-17IKB Heat Sink Replacement: 手順 6、 2の画像 2
    • Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
    • When removing the battery, use care to keep it flat and do not open the battery because it can result in fire or explosion.
  7. Lenovo Ideapad 320-17IKB Heat Sink Replacement, Fan: 手順 7、 2の画像 1 Lenovo Ideapad 320-17IKB Heat Sink Replacement, Fan: 手順 7、 2の画像 2
    • Remove five 7mm Phillips #00 screws from the cooling fan.
  8. Lenovo Ideapad 320-17IKB Heat Sink Replacement: 手順 8、 3の画像 1 Lenovo Ideapad 320-17IKB Heat Sink Replacement: 手順 8、 3の画像 2 Lenovo Ideapad 320-17IKB Heat Sink Replacement: 手順 8、 3の画像 3
    • Gently lift the fan assembly out of the laptop.
    • Gently remove the connecting wires from the exterior of the fan by slowly "weaving" the cord between the ridges of the fan.
  9. Lenovo Ideapad 320-17IKB Heat Sink Replacement, Heat Sink: 手順 9、 3の画像 1 Lenovo Ideapad 320-17IKB Heat Sink Replacement, Heat Sink: 手順 9、 3の画像 2 Lenovo Ideapad 320-17IKB Heat Sink Replacement, Heat Sink: 手順 9、 3の画像 3
    • Gently lift and remove the heat sink and set it aside.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Kristen Gismondi
メンバー登録日: 11/12/14
82,570 ポイント
201のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,410のガイドは作成済み
コメント 1 件
Guys, did you notice the hole in the heat sink just above the processor? Doesn't it make the heatsink less effective?
Neeraj - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 15
今までの合計 487
