Be sure to power off and unplug your device before you begin your repair.
Orient the laptop so the top is laying flat on your work surface.
Remove ten 1.5mm Torx T5 screws from the back of the laptop.
Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
Remove the back cover.
Using tweezers, disconnect the speaker on the left from the USB daugterboard.
Remove two 2.5 mm Phillips #0 screws from the daughterboard.
Remove the daughterboard from the laptop.
Using a spudger, disconnect the keyboard ribbon cable from the motherboard.
Pull on the plastic film to remove the display connection cable.
Using tweezers, disconnect the connections for the right speaker.
Using tweezers, disconnect the connections for the battery.
Using tweezers, disconnect the connections for the CMOS battery.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
