メインコンテンツにスキップ
はじめに
This guide will give you a step by step process on how to replace a daughterboard for a Lenovo IdeaPad 120s-14IAP, including the USB headphone jack, micro SD card reader and NOVO button.
  1. Be sure to power off and unplug your device before you begin your repair.
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
  2. Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
  3. Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard. Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
    • Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
  4. Using tweezers, disconnect the speaker on the left from the USB daugterboard.
    • Using tweezers, disconnect the speaker on the left from the USB daugterboard.
    • Remove two 2.5 mm Phillips #0 screws from the daughterboard.
    • Remove the daughterboard from the laptop.
終わりに
Robert Harper
メンバー登録日: 2019年09月17日
150 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 21
今までの合計 383
