はじめに
If you need to replace a faulty LCD screen in a Lenovo 120s-14IAP, this guide will help you step by step. But be sure to be gentle with the LCD’s electrical connector on the last step.
ツール
パーツ
Open your laptop and insert the Jimmy into the space between the plastic screen cover and the laptop back.
Run the Jimmy along the edge and carefully pull the cover outward as you go.
Once you have completely detached the screen cover from around the edges, gently pull and remove the cover.
2 の人々がこのガイドを完成させました。
