メインコンテンツにスキップ
Lenovo Ideapad 120s-14IAP LCD Screen Replacement
必要な工具と部品
  1. Lenovo Ideapad 120s-14IAP LCD Screen Replacement, LCD Screen: 手順 1、 1の画像 1
    • Open your laptop and insert the Jimmy into the space between the plastic screen cover and the laptop back.
    • Run the Jimmy along the edge and carefully pull the cover outward as you go.
    • Once you have completely detached the screen cover from around the edges, gently pull and remove the cover.
  2. Lenovo Ideapad 120s-14IAP LCD Screen Replacement: 手順 2、 1の画像 1
    • Remove four Phillips #0 screws from the corners of the LCD screen to detach the screen from the mounts.
    • The screen is still attached by an electrical connector at the bottom, so don't completely remove the screen quite yet. Be ready to catch the top, as it will want to fall forward.
  3. Lenovo Ideapad 120s-14IAP LCD Screen Replacement: 手順 3、 1の画像 1
    • Lean the LCD screen forward to expose the display connection near the base.
    • Remove the display connector by placing your thumbnail under the connector latch, and gently pull the LCD screen.
    • The LCD screen can now be removed.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Kyle P Sumpter
メンバー登録日: 09/17/19
363 ポイント
2のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 14
今までの合計 1,194
