メインコンテンツにスキップ
Lenovo IdeaTab S2109A-F System Board Replacement
必要な工具と部品
  1. Lenovo IdeaTab S2109A-F System Board Replacement, Battery: 手順 1、 2の画像 1 Lenovo IdeaTab S2109A-F System Board Replacement, Battery: 手順 1、 2の画像 2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F System Board Replacement: 手順 2、 2の画像 1 Lenovo IdeaTab S2109A-F System Board Replacement: 手順 2、 2の画像 2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F System Board Replacement: 手順 3、 1の画像 1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
  4. Lenovo IdeaTab S2109A-F System Board Replacement, Unscrewing the System Board: 手順 4、 2の画像 1 Lenovo IdeaTab S2109A-F System Board Replacement, Unscrewing the System Board: 手順 4、 2の画像 2
    • Locate the long, L-shaped system board; copper foil runs most of its length.
    • Remove the 10 2mm PH00 black screws located on the edges of the system board using a PH00 Screwdriver.
  5. Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the First Connection to the System Board: 手順 5、 1の画像 1
    • First Disconnect the gold connector by lifting the latch on it up and pulling it loose using the latch to pull.
  6. Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the next three connections of the System Board: 手順 6、 2の画像 1 Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the next three connections of the System Board: 手順 6、 2の画像 2
    • As you lift the board up you will notice two more connections, one near the power switch and one on the I/O Panel.
    • Remove each one with a minimal amount of upward pulling force as you flip the board over.
  7. Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the final connector of the System Board.: 手順 7、 3の画像 1 Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the final connector of the System Board.: 手順 7、 3の画像 2 Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the final connector of the System Board.: 手順 7、 3の画像 3
    • To disconnect the system board there is one last connection.
    • Lift up the back latch on this connection and the orange ribbon should slide right out without any effort thus disconnecting the board.
終わりに
作成者
2人の作成者と共同で作成されました。
Timothy
メンバー登録日: 01/30/15
301 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 17-3, Watkins Winter 2015 USF Tampa, Team 17-3, Watkins Winter 2015人のメンバー
USFT-WATKINS-W15S17G3
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 501
