メインコンテンツにスキップ
Lenovo IdeaTab S2109A-F Speaker Replacement
必要な工具と部品
  1. Lenovo IdeaTab S2109A-F Speaker Replacement, Battery: 手順 1、 2の画像 1 Lenovo IdeaTab S2109A-F Speaker Replacement, Battery: 手順 1、 2の画像 2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Speaker Replacement: 手順 2、 2の画像 1 Lenovo IdeaTab S2109A-F Speaker Replacement: 手順 2、 2の画像 2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Speaker Replacement: 手順 3、 1の画像 1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
  4. Lenovo IdeaTab S2109A-F Speaker Replacement, Speaker: 手順 4、 2の画像 1 Lenovo IdeaTab S2109A-F Speaker Replacement, Speaker: 手順 4、 2の画像 2
    • Remove the ten 2 mm black screws from the edges of the system board with a Phillips #00 screwdriver.
  5. Lenovo IdeaTab S2109A-F Speaker Replacement: 手順 5、 1の画像 1
    • Disconnect the gold connector by lifting the latch with the plastic opening tool.
  6. Lenovo IdeaTab S2109A-F Speaker Replacement: 手順 6、 2の画像 1 Lenovo IdeaTab S2109A-F Speaker Replacement: 手順 6、 2の画像 2
    • Pull up on the L-shaped board.
    • The bottom and top connection points should disconnect.
  7. Lenovo IdeaTab S2109A-F Speaker Replacement: 手順 7、 2の画像 1 Lenovo IdeaTab S2109A-F Speaker Replacement: 手順 7、 2の画像 2
    • Remove the seven 2 mm black screws connecting the speakers using the Phillips #00 screwdriver.
  8. Lenovo IdeaTab S2109A-F Speaker Replacement: 手順 8、 3の画像 1 Lenovo IdeaTab S2109A-F Speaker Replacement: 手順 8、 3の画像 2 Lenovo IdeaTab S2109A-F Speaker Replacement: 手順 8、 3の画像 3
    • Lift the disconnected speakers from their resting position.
    • Grab the red and black cable with your index finger and thumb.
  9. Lenovo IdeaTab S2109A-F Speaker Replacement: 手順 9、 1の画像 1
    • Pull up on the connection to disconnect the speakers.
終わりに
作成者
5人の作成者と共同で作成されました。
Caelen
メンバー登録日: 01/16/15
228 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 17-3, Watkins Winter 2015 USF Tampa, Team 17-3, Watkins Winter 2015人のメンバー
USFT-WATKINS-W15S17G3
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 449
