メインコンテンツにスキップ
Lenovo IdeaTab S2109A-F Battery Replacement
必要な工具と部品
  1. Lenovo IdeaTab S2109A-F Battery Replacement, Battery: 手順 1、 2の画像 1 Lenovo IdeaTab S2109A-F Battery Replacement, Battery: 手順 1、 2の画像 2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Battery Replacement: 手順 2、 2の画像 1 Lenovo IdeaTab S2109A-F Battery Replacement: 手順 2、 2の画像 2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Battery Replacement: 手順 3、 1の画像 1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
11人の作成者と共同で作成されました。
Caelen
メンバー登録日: 01/16/15
228 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 17-3, Watkins Winter 2015 USF Tampa, Team 17-3, Watkins Winter 2015人のメンバー
USFT-WATKINS-W15S17G3
4 メンバー
10のガイドは作成済み
2 件のコメント
Folks this is not easy! The first thing that happened, my screen broke. Then it took about thirty minutes to finally get the back off and the on-off swithch was damaged. Take it to a shop and let them do the damage, then its up to them to pay for it or replace it. I’m now out a s2109 Lenovo tablet because the instructions said easy. Maybe his was. This one sure as heck was not!!
jangoodman - 返信
Theres some screws missing from the directions, under the speakers and in a hole along one side. Tiny torx on the side.
Devin Holland - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 1,533
