はじめに
Use this guide to replace the WIFI/GPS antenna
必要な工具と部品
Look at the back of the tablet and locate the speakers on top of the rear cover.
There is a smaller indentation in the plastic cover that runs across the top of the device.
Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
Remove two black 3mm Phillips #00 screws.
Remove three silver 1.8 mm Phillips #00 screws.
Once the system board has been removed, you can access the WIFI/GPS antenna.
2 の人々がこのガイドを完成させました。
