メインコンテンツにスキップ
Lenovo IdeaTab A1000L Power and Volume Buttons Replacement
必要な工具と部品
  1. Lenovo IdeaTab A1000L Power and Volume Buttons Replacement, Power and Volume Buttons: 手順 1、 3の画像 1 Lenovo IdeaTab A1000L Power and Volume Buttons Replacement, Power and Volume Buttons: 手順 1、 3の画像 2 Lenovo IdeaTab A1000L Power and Volume Buttons Replacement, Power and Volume Buttons: 手順 1、 3の画像 3
    • Be sure to power off your device before taking it apart.
    • Locate the small tab, marked with the lock symbol on the upper right hand of your IdeaTab above the volume control buttons. Use your fingernail to gently loosen this tab.
    • Use your Phillips #000 screwdriver and remove the 3.5mm screw and put it aside.
    • Using your blue, plastic opening tool, begin to gently pry the back panel away from the front panel starting by where the screw was.
  2. Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 手順 2、 2の画像 1 Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 手順 2、 2の画像 2
    • Locate the volume control button on the right hand side of the tablet.
    • Now, gently slide the volume button upward to remove.
  3. Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 手順 3、 3の画像 1 Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 手順 3、 3の画像 2 Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 手順 3、 3の画像 3
    • Locate the black back plate, above the battery.
    • Using a Phillips #000 screwdriver remove the 7 silver 3.5mm screws from the back plate.
    • Next with the same screwdriver remove the black 4.1mm screw.
    • Gently remove the back plate from the device.
  4. Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 手順 4、 3の画像 1 Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 手順 4、 3の画像 2 Lenovo IdeaTab A1000L Power and Volume Buttons Replacement: 手順 4、 3の画像 3
    • Locate the power button on the top right hand corner of your device.
    • Gently slide the button up to remove.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Lauren Pluim
メンバー登録日: 04/22/14
428 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 7-21, Regan Spring 2014 Cal Poly, Team 7-21, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S7G21
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 9
今までの合計 5,258
