はじめに
Here are some easy to follow steps on how to replace your tablet's power and volume buttons.
必要な工具と部品
Locate the small tab, marked with the lock symbol on the upper right hand of your IdeaTab above the volume control buttons. Use your fingernail to gently loosen this tab.
Use your Phillips #000 screwdriver and remove the 3.5mm screw and put it aside.
Using your blue, plastic opening tool, begin to gently pry the back panel away from the front panel starting by where the screw was.
3 の人々がこのガイドを完成させました。
