メインコンテンツにスキップ
Lenovo IdeaPad Yoga 11S RAM Replacement
必要な工具と部品
  1. Lenovo IdeaPad Yoga 11S RAM Replacement, Top Assembly: 手順 1、 3の画像 1 Lenovo IdeaPad Yoga 11S RAM Replacement, Top Assembly: 手順 1、 3の画像 2 Lenovo IdeaPad Yoga 11S RAM Replacement, Top Assembly: 手順 1、 3の画像 3
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
  2. Lenovo IdeaPad Yoga 11S RAM Replacement, Remove Keyboard: 手順 2、 1の画像 1
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S RAM Replacement: 手順 3、 1の画像 1
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S RAM Replacement: 手順 4、 3の画像 1 Lenovo IdeaPad Yoga 11S RAM Replacement: 手順 4、 3の画像 2 Lenovo IdeaPad Yoga 11S RAM Replacement: 手順 4、 3の画像 3
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
  5. Lenovo IdeaPad Yoga 11S RAM Replacement, RAM: 手順 5、 3の画像 1 Lenovo IdeaPad Yoga 11S RAM Replacement, RAM: 手順 5、 3の画像 2 Lenovo IdeaPad Yoga 11S RAM Replacement, RAM: 手順 5、 3の画像 3
    • Locate the RAM module.
    • Locate the tabs on both sides of the RAM module
    • Spread both tabs outward at the same time in order to release the RAM module.
  6. Lenovo IdeaPad Yoga 11S RAM Replacement: 手順 6、 1の画像 1
    • Grab the RAM module and carefully pull it out from its position.
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Landon Epps
メンバー登録日: 03/26/15
982 ポイント
5のガイドは作成済み
チーム
Baylor, Team 7-11, Williams Spring 2015 Baylor, Team 7-11, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S7G11
3 メンバー
10のガイドは作成済み
2 件のコメント
Excelente… easy and simply.
Iver Antelo - 返信
At Step 3. Replace the memory now that it is exposed. You don't have to do steps 4-5, I don't think you have to remove the 10 small screws either.
Just the Philips under the foot tabs and carefully remove the keyboard, pull the tabs back that secure the memory and replace with new memory.
Kyle Brock - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 18
今までの合計 9,038
