メインコンテンツにスキップ
Lenovo IdeaPad Yoga 11S Display Replacement
必要な工具と部品
  1. Lenovo IdeaPad Yoga 11S Display Replacement, Top Assembly: 手順 1、 3の画像 1 Lenovo IdeaPad Yoga 11S Display Replacement, Top Assembly: 手順 1、 3の画像 2 Lenovo IdeaPad Yoga 11S Display Replacement, Top Assembly: 手順 1、 3の画像 3
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
  2. Lenovo IdeaPad Yoga 11S Display Replacement, Remove Keyboard: 手順 2、 1の画像 1
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S Display Replacement: 手順 3、 1の画像 1
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S Display Replacement: 手順 4、 3の画像 1 Lenovo IdeaPad Yoga 11S Display Replacement: 手順 4、 3の画像 2 Lenovo IdeaPad Yoga 11S Display Replacement: 手順 4、 3の画像 3
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
  5. Lenovo IdeaPad Yoga 11S Display Replacement, Display: 手順 5、 1の画像 1
    • Keep the device positioned where it sits on the bottom encasing with the display open.
    • Locate the four 1.9mm screws used to attach the display brackets to the bottom enclosure of the device.
    • Use a Phillips #00 Screwdriver to remove the four screws.
  6. Lenovo IdeaPad Yoga 11S Display Replacement: 手順 6、 1の画像 1
    • Use a plastic opening tool to lift the retaining flap to disconnect the right display cable connector.
    • Gently pull the display cable out of the socket.
  7. Lenovo IdeaPad Yoga 11S Display Replacement: 手順 7、 1の画像 1
    • Use a plastic opening tool to lift the retaining flap to disconnect the left display cable connector.
  8. Lenovo IdeaPad Yoga 11S Display Replacement: 手順 8、 1の画像 1
    • Gently lift the display to detach it from the device.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Landon Epps
メンバー登録日: 03/26/15
982 ポイント
5のガイドは作成済み
チーム
Baylor, Team 7-11, Williams Spring 2015 Baylor, Team 7-11, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S7G11
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 4,994
