メインコンテンツにスキップ
Lenovo IdeaPad Y580-2099 Motherboard Replacement
必要な工具と部品
  1. Lenovo IdeaPad Y580-2099 Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Slide out both locks for the battery, located on the back of the device.
  2. Lenovo IdeaPad Y580-2099 Motherboard Replacement: 手順 2、 2の画像 1 Lenovo IdeaPad Y580-2099 Motherboard Replacement: 手順 2、 2の画像 2
    • Remove the battery.
  3. Lenovo IdeaPad Y580-2099 Motherboard Replacement, Keyboard: 手順 3、 2の画像 1 Lenovo IdeaPad Y580-2099 Motherboard Replacement, Keyboard: 手順 3、 2の画像 2
    • Unscrew the 2 screws on the bottom of the device.
    • Slide the back panel out.
  4. Lenovo IdeaPad Y580-2099 Motherboard Replacement: 手順 4、 1の画像 1
    • Unscrew the 3 "keyboard" detected screws.
  5. Lenovo IdeaPad Y580-2099 Motherboard Replacement: 手順 5、 2の画像 1 Lenovo IdeaPad Y580-2099 Motherboard Replacement: 手順 5、 2の画像 2
    • Flip the laptop over and open up.
    • Then pry up the whole keyboard using the spudger.
    • Make sure to use a plastic spudger. You could damage the device using anything else.
    • Make sure not to take the frame that goes around the keys off. This part is not removable.
  6. Lenovo IdeaPad Y580-2099 Motherboard Replacement, Motherboard: 手順 6、 3の画像 1 Lenovo IdeaPad Y580-2099 Motherboard Replacement, Motherboard: 手順 6、 3の画像 2 Lenovo IdeaPad Y580-2099 Motherboard Replacement, Motherboard: 手順 6、 3の画像 3
    • Flip laptop back over and unscrew the disc drive screw.
    • Remove the disc drive.
    • Unscrew all of the screws on the back of the device.
  7. Lenovo IdeaPad Y580-2099 Motherboard Replacement: 手順 7、 3の画像 1 Lenovo IdeaPad Y580-2099 Motherboard Replacement: 手順 7、 3の画像 2 Lenovo IdeaPad Y580-2099 Motherboard Replacement: 手順 7、 3の画像 3
    • Flip the device over.
    • Unplug the two wires, as shown in the images.
    • Lift up on the keyboard bezel.
    • The bezel should come up easy, if not go back and make sure all screws have been removed.
  8. Lenovo IdeaPad Y580-2099 Motherboard Replacement: 手順 8、 2の画像 1 Lenovo IdeaPad Y580-2099 Motherboard Replacement: 手順 8、 2の画像 2
    • Unscrew the screws on the motherboard.
    • Disconnect the three connectors the two black and one white.
  9. Lenovo IdeaPad Y580-2099 Motherboard Replacement: 手順 9、 1の画像 1
    • Carefully lift up the motherboard.
    • Unplug the wires underneath the motherboard.
    • Be careful not to rip the wires underneath the motherboard while lifting it up.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Lauren
メンバー登録日: 09/25/17
481 ポイント
4のガイドは作成済み
チーム
University of North Texas, Team S1-G5, Thompson Fall 2017 University of North Texas, Team S1-G5, Thompson Fall 2017人のメンバー
UNT-THOMPSON-F17S1G5
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 1,562
