メインコンテンツにスキップ
Lenovo IdeaPad Y580-2099 Daughterboard Replacement
必要な工具と部品
  1. Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Battery: 手順 1、 1の画像 1
    • Slide out both locks for the battery, located on the back of the device.
  2. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: 手順 2、 2の画像 1 Lenovo IdeaPad Y580-2099 Daughterboard Replacement: 手順 2、 2の画像 2
    • Remove the battery.
  3. Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Keyboard: 手順 3、 2の画像 1 Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Keyboard: 手順 3、 2の画像 2
    • Unscrew the 2 screws on the bottom of the device.
    • Slide the back panel out.
  4. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: 手順 4、 1の画像 1
    • Unscrew the 3 "keyboard" detected screws.
  5. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: 手順 5、 2の画像 1 Lenovo IdeaPad Y580-2099 Daughterboard Replacement: 手順 5、 2の画像 2
    • Flip the laptop over and open up.
    • Then pry up the whole keyboard using the spudger.
    • Make sure to use a plastic spudger. You could damage the device using anything else.
    • Make sure not to take the frame that goes around the keys off. This part is not removable.
  6. Lenovo IdeaPad Y580-2099 Daughterboard Replacement, Daughterboard: 手順 6、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the 16 screws highlighted. There are 12 M2.5 x 8 mm long screws, and 4 M2 x 2 mm long screws.
    • Use a Phillips #0 screwdriver to remove the 10 mm screw (highlighted in orange) that secures the disc drive.
    • Quickly survey and make sure all screws on the back panel are removed from the device.
    • Some of the screws may have been removed in previous steps.
  7. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: 手順 7、 1の画像 1
    • Carefully slide the disc drive out.
  8. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: 手順 8、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the three M2 x 3 mm long screws circled in red.
  9. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: 手順 9、 1の画像 1
    • Lift open the top panel carefully as there are wire cables secured to the motherboard.
  10. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: 手順 10、 1の画像 1
    この手順で使用する道具:
    購入する
    • After locating the cable holding the top panel in place, carefully unhook the handle using precision tweezers.
    • Carefully remove the top plate.
  11. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: 手順 11、 1の画像 1
    • Now that the top plate is removed, locate the daughter board. (Highlighted in Red).
  12. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: 手順 12、 1の画像 1
    • Use a plastic spudger or precision tweezers to carefully unhook the daughterboard cables.
  13. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: 手順 13、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the two M2.5 x 3 mm long screws that secure the daughterboard.
  14. Lenovo IdeaPad Y580-2099 Daughterboard Replacement: 手順 14、 1の画像 1
    • Check and make sure all screws and cable wires are detached before attempting to remove the daughterboard.
    • Carefully remove the daughterboard.
終わりに
作成者
4人の作成者と共同で作成されました。
Jeryn Fast
メンバー登録日: 04/12/22
421 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 1-1, Beck Spring 2022 IUPUI, Team 1-1, Beck Spring 2022人のメンバー
IUPUI-BECK-S22S1G1
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 152
