メインコンテンツにスキップ
Lenovo IdeaPad Y400 Motherboard Replacement
必要な工具と部品
  1. Lenovo IdeaPad Y400 Motherboard Replacement, Battery: 手順 1、 3の画像 1 Lenovo IdeaPad Y400 Motherboard Replacement, Battery: 手順 1、 3の画像 2 Lenovo IdeaPad Y400 Motherboard Replacement, Battery: 手順 1、 3の画像 3
    • Make sure the laptop is upside down, then turn the laptop so that the battery is facing you. Now that the battery is facing you, there will be two locks, one on the left and one on the right.
    • Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red.
  2. Lenovo IdeaPad Y400 Motherboard Replacement: 手順 2、 2の画像 1 Lenovo IdeaPad Y400 Motherboard Replacement: 手順 2、 2の画像 2
    • Unlike the first lock, the left lock does not stay in place. You will need to hold it in place as you take the battery out.
    • Slide the second (left) lock to the left and hold it there.
  3. Lenovo IdeaPad Y400 Motherboard Replacement: 手順 3、 1の画像 1
    • Gently pull the battery out.
  4. Lenovo IdeaPad Y400 Motherboard Replacement, Back Panel: 手順 4、 1の画像 1
    • Remove the eight 9mm screws with a Phillips #0 screwdriver.
  5. Lenovo IdeaPad Y400 Motherboard Replacement: 手順 5、 3の画像 1 Lenovo IdeaPad Y400 Motherboard Replacement: 手順 5、 3の画像 2 Lenovo IdeaPad Y400 Motherboard Replacement: 手順 5、 3の画像 3
    • Use the plastic opening tool to remove the back panel from the device.
    • Do not force the back off, as you may break the clips keeping it down.
  6. Lenovo IdeaPad Y400 Motherboard Replacement, Optical Drive: 手順 6、 2の画像 1 Lenovo IdeaPad Y400 Motherboard Replacement, Optical Drive: 手順 6、 2の画像 2
    • Move the lock down until you see red and hear a slight click.
  7. Lenovo IdeaPad Y400 Motherboard Replacement: 手順 7、 3の画像 1 Lenovo IdeaPad Y400 Motherboard Replacement: 手順 7、 3の画像 2 Lenovo IdeaPad Y400 Motherboard Replacement: 手順 7、 3の画像 3
    • Hold this lock down while removing the optical drive.
  8. Lenovo IdeaPad Y400 Motherboard Replacement, Motherboard: 手順 8、 1の画像 1
    • Unscrew the screws using a Phillips #0 screwdriver.
    • Unplug the wireless adapter to fully remove the motherboard.
    • If you don't want to break any of the parts you might want to take out the RAM, SSD, and the Hard Drive.
    • Screw sizes will be 4mm and 9mm
  9. Lenovo IdeaPad Y400 Motherboard Replacement: 手順 9、 3の画像 1 Lenovo IdeaPad Y400 Motherboard Replacement: 手順 9、 3の画像 2 Lenovo IdeaPad Y400 Motherboard Replacement: 手順 9、 3の画像 3
    • Use the plastic opening tool to take off the front panel.
    • Unplug the blue wire to remove the front panel.
  10. Lenovo IdeaPad Y400 Motherboard Replacement: 手順 10、 1の画像 1
    • Fully remove the front panel.
    • Unscrew the 9mm and 4mm screws (there is one of each screw).
  11. Lenovo IdeaPad Y400 Motherboard Replacement: 手順 11、 2の画像 1 Lenovo IdeaPad Y400 Motherboard Replacement: 手順 11、 2の画像 2
    • After unscrewing the screws, remove the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Rachel Simmons
メンバー登録日: 09/26/18
603 ポイント
6のガイドは作成済み
チーム
University of North Texas, Team S7-G5, Thompson Fall 2018 University of North Texas, Team S7-G5, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S7G5
2 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 763
