メインコンテンツにスキップ
Lenovo IdeaPad U530 Touch Hard Drive Replacement
必要な工具と部品
  1. Lenovo IdeaPad U530 Touch Hard Drive Replacement, Battery: 手順 1、 3の画像 1 Lenovo IdeaPad U530 Touch Hard Drive Replacement, Battery: 手順 1、 3の画像 2 Lenovo IdeaPad U530 Touch Hard Drive Replacement, Battery: 手順 1、 3の画像 3
    • Remove the back panel by removing all screws. Use a PH000 screwdriver head.
    • Make sure to also remove the hinge screws.
  2. Lenovo IdeaPad U530 Touch Hard Drive Replacement: 手順 2、 2の画像 1 Lenovo IdeaPad U530 Touch Hard Drive Replacement: 手順 2、 2の画像 2
    • To remove the panel, use a plastic opening tool to prevent any damage.
  3. Lenovo IdeaPad U530 Touch Hard Drive Replacement: 手順 3、 1の画像 1
    • Locate and assess the battery. Pictured in the upper right area of the computer.
  4. Lenovo IdeaPad U530 Touch Hard Drive Replacement: 手順 4、 2の画像 1 Lenovo IdeaPad U530 Touch Hard Drive Replacement: 手順 4、 2の画像 2
    • Locate and remove all screws attaching the battery to the hull of the computer. It is recommended that you use a JIS #1 screwdriver head for this task.
    • Be careful to keep track of all removed screws.
  5. Lenovo IdeaPad U530 Touch Hard Drive Replacement: 手順 5、 1の画像 1
    • Detach the connection from the battery to the motherboard. This is the only connection that needs to be disconnected for the battery.
    • To remove the connection, please pull firmly, as it well secured.
  6. Lenovo IdeaPad U530 Touch Hard Drive Replacement: 手順 6、 1の画像 1
    • Simply lift the battery out of the computer, and acquire a replacement.
  7. Lenovo IdeaPad U530 Touch Hard Drive Replacement, Hard Drive: 手順 7、 3の画像 1 Lenovo IdeaPad U530 Touch Hard Drive Replacement, Hard Drive: 手順 7、 3の画像 2 Lenovo IdeaPad U530 Touch Hard Drive Replacement, Hard Drive: 手順 7、 3の画像 3
    • Remove two 3 mm screws connecting the hard drive to the computer base using a JIS #1 screwdriver.
    • Detach the connection from the hard drive to the motherboard.
    • Remove the hard drive from the laptop.
終わりに
作成者
2人の作成者と共同で作成されました。
Jack Dunn
メンバー登録日: 09/20/21
73 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 5
過去 30 日: 8
今までの合計 696
