はじめに
This is a very simple process, where laptop batteries usually start to go bad after 2 years, they can easily be purchased online and swapped out for new.
必要な工具と部品
Power off your computer before you begin.
Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
Using a combination of plastic opening tool and spudger, press in on the clips on the sides of the battery connector and push the connector out
When you get the connector out far enough, grab behind the connector tabs with tweezers and wiggle the connector the rest of the way out.
3 の人々がこのガイドを完成させました。
