はじめに
This screen replacement guide will show you how to replace your defective LCD screen on your Lenovo U410. You will need a Phillips #1 screwdriver and a metal spudger. Be careful when removing the plastic trim and connectors because you can easily break them.
必要な工具と部品
Power off the laptop.
Using the metal spudger, gently pry off the black trim around the screen.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
