はじめに
If your battery no longer holds a charge or stops functioning all together, use this guide to remove and replace the battery. No tools required.
  1. Locate the battery by turning the laptop over.
    • Locate the battery by turning the laptop over.
  2. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. Locate the lock switch and slide toward the outside edge of the laptop until it clicks into place and the battery unit pops up. Remove the battery unit from the laptop and set it aside. Remove the battery unit from the laptop and set it aside.
    • Locate the lock switch and slide toward the outside edge of the laptop until it clicks into place and the battery unit pops up.
    • Remove the battery unit from the laptop and set it aside.
まとめ
Katherine
メンバー登録日: 2014年08月13日
101 ポイント
1ガイドが承認済み
チーム
iFixit, Team 1-1, Suovanen Fall 2014 iFixit, Team 1-1, Suovanen Fall 2014人のメンバー
FIX-SUOVANEN-F14S1G1
3 メンバー
1のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 1,046
