メインコンテンツにスキップ
Lenovo IdeaPad U310 Screen Replacement
必要な工具と部品
  1. Lenovo IdeaPad U310 Screen  Replacement, Battery: 手順 1、 1の画像 1
    • Flip the device over so the bottom panel is facing up.
    • Remove the rubber feet by pinching and pulling in an upward motion.
    • The rubber feet are missing from this photo, but will be located within the red markups.
  2. Lenovo IdeaPad U310 Screen  Replacement: 手順 2、 1の画像 1
    • Remove the 4 screws securing the bottom panel to the device.
    • The screws are missing from this device and are not pictured. They will be located under the rubber feet within the red markups.
  3. Lenovo IdeaPad U310 Screen  Replacement: 手順 3、 2の画像 1 Lenovo IdeaPad U310 Screen  Replacement: 手順 3、 2の画像 2
    • Place the plastic opening tool between the bottom panel and device.
    • Pry around the device's outer edge until the bottom panel is no longer attached.
    • Lift the bottom panel up and away from device.
  4. Lenovo IdeaPad U310 Screen  Replacement: 手順 4、 2の画像 1 Lenovo IdeaPad U310 Screen  Replacement: 手順 4、 2の画像 2
    • Unplug the Battery from the circuit board by carefully prying the connector from its housing.
  5. Lenovo IdeaPad U310 Screen  Replacement: 手順 5、 2の画像 1 Lenovo IdeaPad U310 Screen  Replacement: 手順 5、 2の画像 2
    • Remove the 5.6 mm Screw with the PH1 screwdriver.
    • Remove the 4.6 mm screws with the PH1 screwdriver.
  6. Lenovo IdeaPad U310 Screen  Replacement: 手順 6、 2の画像 1 Lenovo IdeaPad U310 Screen  Replacement: 手順 6、 2の画像 2
    • Lift the strip tape away from the battery, being careful not to completely remove it.
  7. Lenovo IdeaPad U310 Screen  Replacement: 手順 7、 1の画像 1
    • Remove the battery by lifting up and away from device.
  8. Lenovo IdeaPad U310 Screen  Replacement, Screen: 手順 8、 1の画像 1
    • Insert opening tool between the frame and the back panel of the screen.
  9. Lenovo IdeaPad U310 Screen  Replacement: 手順 9、 1の画像 1
    • Work your way around the frame until every connection is loose.
  10. Lenovo IdeaPad U310 Screen  Replacement: 手順 10、 1の画像 1
    • Lift the screen up and away from the device.
    • Do not tamper with the tape on the bottom of the screen labeled "Don't touch".
  11. Lenovo IdeaPad U310 Screen  Replacement: 手順 11、 2の画像 1 Lenovo IdeaPad U310 Screen  Replacement: 手順 11、 2の画像 2
    • Remove the 1.9 mm screws using the PH0 screwdriver.
    • These screws are very short and small, keep track of them.
  12. Lenovo IdeaPad U310 Screen  Replacement: 手順 12、 2の画像 1 Lenovo IdeaPad U310 Screen  Replacement: 手順 12、 2の画像 2
    • Once the four screws are removed, gently rest the screen facedown on the keyboard.
  13. Lenovo IdeaPad U310 Screen  Replacement: 手順 13、 2の画像 1 Lenovo IdeaPad U310 Screen  Replacement: 手順 13、 2の画像 2
    • Peel back the white tape, revealing the power connection.
  14. Lenovo IdeaPad U310 Screen  Replacement: 手順 14、 2の画像 1 Lenovo IdeaPad U310 Screen  Replacement: 手順 14、 2の画像 2
    • Unplug the connector, pulling it by the white tape.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Andrew Capra
メンバー登録日: 09/28/16
388 ポイント
3のガイドは作成済み
チーム
Eastern Washington University, Team 2-1, Mathisen Fall 2016 Eastern Washington University, Team 2-1, Mathisen Fall 2016人のメンバー
EWU-MATHISEN-F16S2G1
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 19
今までの合計 5,113
