メインコンテンツにスキップ
Lenovo IdeaPad U310 Keyboard Replacement
必要な工具と部品
  1. Lenovo IdeaPad U310 Keyboard  Replacement, Battery: 手順 1、 1の画像 1
    • Flip the device over so the bottom panel is facing up.
    • Remove the rubber feet by pinching and pulling in an upward motion.
    • The rubber feet are missing from this photo, but will be located within the red markups.
  2. Lenovo IdeaPad U310 Keyboard  Replacement: 手順 2、 1の画像 1
    • Remove the 4 screws securing the bottom panel to the device.
    • The screws are missing from this device and are not pictured. They will be located under the rubber feet within the red markups.
  3. Lenovo IdeaPad U310 Keyboard  Replacement: 手順 3、 2の画像 1 Lenovo IdeaPad U310 Keyboard  Replacement: 手順 3、 2の画像 2
    • Place the plastic opening tool between the bottom panel and device.
    • Pry around the device's outer edge until the bottom panel is no longer attached.
    • Lift the bottom panel up and away from device.
  4. Lenovo IdeaPad U310 Keyboard  Replacement: 手順 4、 2の画像 1 Lenovo IdeaPad U310 Keyboard  Replacement: 手順 4、 2の画像 2
    • Unplug the Battery from the circuit board by carefully prying the connector from its housing.
  5. Lenovo IdeaPad U310 Keyboard  Replacement: 手順 5、 2の画像 1 Lenovo IdeaPad U310 Keyboard  Replacement: 手順 5、 2の画像 2
    • Remove the 5.6 mm Screw with the PH1 screwdriver.
    • Remove the 4.6 mm screws with the PH1 screwdriver.
  6. Lenovo IdeaPad U310 Keyboard  Replacement: 手順 6、 2の画像 1 Lenovo IdeaPad U310 Keyboard  Replacement: 手順 6、 2の画像 2
    • Lift the strip tape away from the battery, being careful not to completely remove it.
  7. Lenovo IdeaPad U310 Keyboard  Replacement: 手順 7、 1の画像 1
    • Remove the battery by lifting up and away from device.
  8. Lenovo IdeaPad U310 Keyboard  Replacement, Keyboard: 手順 8、 2の画像 1 Lenovo IdeaPad U310 Keyboard  Replacement, Keyboard: 手順 8、 2の画像 2
    • Remove the two 4.6 mm screws using PH1.
    • One is located next to the fan, the other at the corner of the battery.
  9. Lenovo IdeaPad U310 Keyboard  Replacement: 手順 9、 2の画像 1 Lenovo IdeaPad U310 Keyboard  Replacement: 手順 9、 2の画像 2
    • Pry up the hinge that houses the keyboard's ribbon cable.
  10. Lenovo IdeaPad U310 Keyboard  Replacement: 手順 10、 1の画像 1
    • Remove the ribbon from its housing.
  11. Lenovo IdeaPad U310 Keyboard  Replacement: 手順 11、 1の画像 1
    • Turn laptop upside down so the keyboard is facing up.
    • Place prying tool between the keyboard and the housing.
    • Move the prying tool around the keyboard's edge, releasing the tabs securing the keyboard.
    • There are larger tabs that cannot be pried at the bottom of the keyboard.
  12. Lenovo IdeaPad U310 Keyboard  Replacement: 手順 12、 1の画像 1
    • Life the keyboard up and away from the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Andrew Capra
メンバー登録日: 09/28/16
388 ポイント
3のガイドは作成済み
チーム
Eastern Washington University, Team 2-1, Mathisen Fall 2016 Eastern Washington University, Team 2-1, Mathisen Fall 2016人のメンバー
EWU-MATHISEN-F16S2G1
5 メンバー
5のガイドは作成済み
コメント 1 件
Honestly, the best instructions for any task i ever made ⭐⭐⭐⭐⭐. Thank you
zakimsaleh - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 17
今までの合計 3,603
