はじめに
Follow this guide to replace the speakers in a Lenovo IdeaPad S400 Touch. Before removing the speakers, follow the troubleshooting steps linked here to make sure there is not a different technical issue causing audio malfunctions. If the problem is rooted in faulty speakers, damaged by physical trauma or another cause, you will need to purchase a set of replacement speakers. A link to purchase replacement speakers can be found in the list of tools and parts.
必要な工具と部品
Turn your computer over so the back is face up.
Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
The battery cover will then pop up allowing you access to the battery.
Remove the five 6mm Phillips #0 screws from the back panel.
Pull back the rubber tabs from the corners of the laptop backing to expose the screws.
Remove the four 4mm Phillips #0 screws that are underneath the rubber tabs.
Remove the three 6mm Phillips #0 screws from under the battery.
ある他の人がこのガイドを完成しました。
