はじめに
To replace the fan, follow this guide.
必要な工具と部品
Turn your computer over so the back is face up.
Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
The battery cover will then pop up allowing you access to the battery.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
