必要な工具と部品
デバイスを再組み立てするには、これらのインストラクションを逆の順番に従って作業を進めてください。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
コメント 1 件
I managed to take the case apart once, but when I tried to put back the Torx screws back in, I noticed one wouldn't go more than halfway -- it then turned freely. I'd ordered an SSD thinking that it would be a simple matter to install it, but I found that half the Torx screws wouldn't come out, even using a tiny screwdriver to try to prise them out while turning the Torx wrench. They're seated in brass sleeves -- no way I stripped those out; the sleeves must be glued into the plastic of the case and the glue given out. There now seems to be no way to take the case apart without destroying it completely.
