メインコンテンツにスキップ
Lenovo IdeaPad S210 Touch Hard Drive Replacement
必要な工具と部品
  1. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Hard Drive Replacement: 手順 2、 2の画像 1 Lenovo IdeaPad S210 Touch Hard Drive Replacement: 手順 2、 2の画像 2
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Back Panel: 手順 3、 2の画像 1 Lenovo IdeaPad S210 Touch Hard Drive Replacement, Back Panel: 手順 3、 2の画像 2
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch Hard Drive Replacement: 手順 4、 1の画像 1
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch Hard Drive Replacement: 手順 5、 3の画像 1 Lenovo IdeaPad S210 Touch Hard Drive Replacement: 手順 5、 3の画像 2 Lenovo IdeaPad S210 Touch Hard Drive Replacement: 手順 5、 3の画像 3
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
  6. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Hard Drive: 手順 6、 2の画像 1 Lenovo IdeaPad S210 Touch Hard Drive Replacement, Hard Drive: 手順 6、 2の画像 2
    • Using a #0 Phillips screwdriver, remove the four 4mm screws that secure the hard drive bracket to the motherboard.
  7. Lenovo IdeaPad S210 Touch Hard Drive Replacement: 手順 7、 2の画像 1 Lenovo IdeaPad S210 Touch Hard Drive Replacement: 手順 7、 2の画像 2
    • Slide your hard drive away from your motherboard until fully removed.
    • Be careful not to snag any wires routed along the battery side of the hard drive.
  8. Lenovo IdeaPad S210 Touch Hard Drive Replacement: 手順 8、 3の画像 1 Lenovo IdeaPad S210 Touch Hard Drive Replacement: 手順 8、 3の画像 2 Lenovo IdeaPad S210 Touch Hard Drive Replacement: 手順 8、 3の画像 3
    • This step is only necessary if you are swapping your old hard drive for a new one.
    • Using a Phillips #0 screwdriver, remove four 2.5mm screws, two per side, to release the hard drive from its mounting bracket. These screws are directly next to each mounting screw you removed previously.
    • Install the mounting brackets onto the new hard drive during reassembly.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Zack Colman
メンバー登録日: 07/08/19
885 ポイント
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 16
今までの合計 1,402
