はじめに
This guide will show you how to replace the battery in your Lenovo IdeaPad S210 Touch. Power down your device before beginning the process.
If your laptop no longer seems capable of holding a charge, or won’t turn on at all, the battery probably needs to be replaced. Replacing the battery may also fix some common problems such as overheating or a shortened battery life.
After enduring countless charging cycles, batteries inevitably begin to drain at a faster rate. If you start consistently noticing a rapid decrease in the lifespan of your laptop battery, be sure to calibrate the battery. If the problem persists, replace the battery.
Please be aware that a punctured battery can cause a dangerous fire. If your battery is swollen, take appropriate precautions.
必要な工具と部品
