はじめに
Replacing the keyboard on your laptop can be necessary if your keyboard is no longer responding. You will need a nylon or metal spudger. Make sure that the power is off before continuing.
必要な工具と部品
Rotate the laptop so the back side is facing you.
From this side, you should be able to see both of the gaps where the two plastic materials meet.
もう少しです!
終わりに
2 の人々がこのガイドを完成させました。
