メインコンテンツにスキップ
Lenovo IdeaPad S10-2 Hard Drive Replacement
必要な工具と部品
  1. Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 1 Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 2
    • Start with laptop closed.
    • Turn laptop over so the back panel is visible, as shown in the second image.
    • Remove the two 40 mm Phillips screws using a Phillips J0 head screwdriver.
  2. Lenovo IdeaPad S10-2 Hard Drive Replacement: 手順 2、 2の画像 1 Lenovo IdeaPad S10-2 Hard Drive Replacement: 手順 2、 2の画像 2
    • Remove both 40 mm Phillips screws using a Phillips J0 head screwdriver.
    • Remove the back panel and set it aside.
  3. Lenovo IdeaPad S10-2 Hard Drive Replacement: 手順 3、 2の画像 1 Lenovo IdeaPad S10-2 Hard Drive Replacement: 手順 3、 2の画像 2
    • Remove the 40 mm screw using a Phillips J0 head screwdriver.
  4. Lenovo IdeaPad S10-2 Hard Drive Replacement: 手順 4、 2の画像 1 Lenovo IdeaPad S10-2 Hard Drive Replacement: 手順 4、 2の画像 2
    • After removing the screw, carefully wedge the flat end of a spudger in the spacing to remove the hard drive from the port.
    • Pry the hard drive out of its port.
    • Push the wedged end of the spudger out as indicated by the action shots.
  5. Lenovo IdeaPad S10-2 Hard Drive Replacement: 手順 5、 2の画像 1 Lenovo IdeaPad S10-2 Hard Drive Replacement: 手順 5、 2の画像 2
    • Carefully lift the hard drive enclosure to remove it from the laptop.
    • The enclosure is the metal case holding the actual hard drive. You must remove the metal case in order to replace the hard drive.
  6. Lenovo IdeaPad S10-2 Hard Drive Replacement: 手順 6、 3の画像 1 Lenovo IdeaPad S10-2 Hard Drive Replacement: 手順 6、 3の画像 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: 手順 6、 3の画像 3
    • The hard drive enclosure has four 40 mm screws keeping the hard drive in place.
    • Remove the four 40 mm screws with a Phillips J0 head screwdriver.
  7. Lenovo IdeaPad S10-2 Hard Drive Replacement: 手順 7、 2の画像 1 Lenovo IdeaPad S10-2 Hard Drive Replacement: 手順 7、 2の画像 2
    • Slide the hard drive out of the enclosure.
    • The new hard drive can be inserted into the same enclosure.
終わりに
作成者
5人の作成者と共同で作成されました。
Anthony
メンバー登録日: 10/13/15
258 ポイント
2のガイドは作成済み
チーム
Sam Houston State, Team 1-7, Blackburne Fall 2015 Sam Houston State, Team 1-7, Blackburne Fall 2015人のメンバー
SHSU-BLACKBURNE-F15S1G7
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 24
今までの合計 9,500
