はじめに
Replacement of the hard drive because of performance issues or to update the hard drive is demonstrated. A dead hard drive will make a loud clicking sound. Replacing the hard drive should solve this problem. Replacing the hard drive because of performance issues or updating the hard drive can improve issues. When replacing the hard drive, you will need a Phillips J0 head screwdriver and a spudger. Make sure that the laptop is powered off before continuing.
必要な工具と部品
Start with laptop closed.
Turn laptop over so the back panel is visible, as shown in the second image.
Remove the two 40 mm Phillips screws using a Phillips J0 head screwdriver.
