メインコンテンツにスキップ
はじめに
Can't watch movies? Change your optical drive with this guide!
パーツ
パーツは指定されていません。
  1. To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left. To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Now push the right clip to the right and hold it while using your other hand to pull the battery out. Now push the right clip to the right and hold it while using your other hand to pull the battery out.
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  4. Remove the two screws highlighted.
    • Remove the two screws highlighted.
  5. This is the back of the laptop with the cover removed.
    • This is the back of the laptop with the cover removed.
  6. Locate and remove the single screw right of the optical drive
    • Locate and remove the single screw right of the optical drive
  7. Optical Drive should slide out easily with one thumb's effort.
    • Optical Drive should slide out easily with one thumb's effort.
まとめ
Christopher
メンバー登録日: 2014年04月08日
666 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 8-7, Regan Spring 2014 Cal Poly, Team 8-7, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S8G7
5 メンバー
10のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 284
