メインコンテンツにスキップ
Lenovo IdeaPad N580 RAM Replacement
必要な工具と部品
  1. Lenovo IdeaPad N580 RAM Replacement, Battery: 手順 1、 1の画像 1
    • Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
  2. Lenovo IdeaPad N580 RAM Replacement: 手順 2、 1の画像 1
    • Move the right switch towards the right until it clicks in place. You should then see the color red reveal from where the switch was originally.
  3. Lenovo IdeaPad N580 RAM Replacement: 手順 3、 1の画像 1
    • Now take your left hand and slide the left switch to the left.
    • This switch will not click in place like the other switch, so make sure to keep your left hand on the switch.
  4. Lenovo IdeaPad N580 RAM Replacement: 手順 4、 1の画像 1
    • Take your free hand and place it on the battery. Gently slide it away from its slot.
  5. Lenovo IdeaPad N580 RAM Replacement, RAM: 手順 5、 1の画像 1
    • Rotate the laptop so that now the hinge is facing away from you.
    • Remove the two 2.5 x 4.0 mm Phillips #0 screws from the underside of the laptop.
  6. Lenovo IdeaPad N580 RAM Replacement: 手順 6、 2の画像 1 Lenovo IdeaPad N580 RAM Replacement: 手順 6、 2の画像 2
    • Slide the bottom panel towards you until it stops, and then carefully lift it off.
  7. Lenovo IdeaPad N580 RAM Replacement: 手順 7、 3の画像 1 Lenovo IdeaPad N580 RAM Replacement: 手順 7、 3の画像 2 Lenovo IdeaPad N580 RAM Replacement: 手順 7、 3の画像 3
    • The RAM sticks can be found at the bottom right of the laptop.
    • Carefully press the two silver buttons on either side of the stick outwards. This will cause the RAM to “pop” up.
    • This device is capable of holding two RAM sticks, so there are two different sets of silver buttons; a top set and a bottom set. When removing the RAM stick, make sure to press either the two bottom buttons or the two top buttons.
  8. Lenovo IdeaPad N580 RAM Replacement: 手順 8、 1の画像 1
    • Carefully slide the RAM straight out of its socket.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Alex Amorim
メンバー登録日: 03/19/18
907 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G2, Peak Spring 2018 UMass Dartmouth, Team S5-G2, Peak Spring 2018人のメンバー
UMASSD-PEAK-S18S5G2
2 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 490
