はじめに
If your Lenovo IdeaPad Flex 5 14ARE05 has poor load times, you may have a full or faulty storage device. The Lenovo IdeaPad Flex 5 14ARE05 has an NVMe SSD for a storage device, if you'd like more storage or faster loading times your SSD is the perfect way for immediate results. Before starting make sure your laptop is powered down and disconnected from all power sources.
必要な工具と部品
Remove the five 8 mm screws using a T5 Torx Screwdriver.
Remove the four 5 mm screws using a T5 Torx Screwdriver.
もう少しです!
終わりに
