メインコンテンツにスキップ
Lenovo IdeaPad Flex 4-1470 Speaker Replacement
必要な工具と部品
  1. Lenovo IdeaPad Flex 4-1470 Speaker Replacement, Lower Case: 手順 1、 1の画像 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: 手順 2、 2の画像 1 Lenovo IdeaPad Flex 4-1470 Speaker Replacement: 手順 2、 2の画像 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Speaker Replacement, Battery: 手順 3、 2の画像 1 Lenovo IdeaPad Flex 4-1470 Speaker Replacement, Battery: 手順 3、 2の画像 2
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: 手順 4、 1の画像 1
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: 手順 5、 1の画像 1
    • Lift the battery up and out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Speaker Replacement, Speaker: 手順 6、 2の画像 1 Lenovo IdeaPad Flex 4-1470 Speaker Replacement, Speaker: 手順 6、 2の画像 2
    • The speakers are not screwed or bolted in like any other components. They have two rubber grommets at each end which hold it in with friction.
    • Starting with the speaker on the right, use your fingers to lift both ends of the speaker off.
    • The grommets may fall off when removing the speaker. When reassembling make sure you place the grommets back into the notches on the speaker before trying to mount the speaker. The specific orientation and position doesn't matter
  7. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: 手順 7、 1の画像 1
    • In addition to the grommets, the speaker wire running to the motherboard is clipped down.
    • Remove speaker wire from the clips.
  8. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: 手順 8、 2の画像 1 Lenovo IdeaPad Flex 4-1470 Speaker Replacement: 手順 8、 2の画像 2
    • Repeat the previous steps for the other speaker.
  9. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: 手順 9、 1の画像 1
    • Remove the wire shown using the plastic opening tool.
  10. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: 手順 10、 2の画像 1 Lenovo IdeaPad Flex 4-1470 Speaker Replacement: 手順 10、 2の画像 2
    • Use the Plastic Opening tool to flip open the ribbon cable clip shown.
    • Pull gently on the ribbon cable to disconnect it from the motherboard.
  11. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: 手順 11、 3の画像 1 Lenovo IdeaPad Flex 4-1470 Speaker Replacement: 手順 11、 3の画像 2 Lenovo IdeaPad Flex 4-1470 Speaker Replacement: 手順 11、 3の画像 3
    • Now that both speaker wires are free, disconnect the speakers from motherboard using two plastic opening tools.
    • Keep in mind that the red and black wires lead to the left speaker and the blue and white wires lead to the right speakers.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Robert Cartwright
メンバー登録日: 10/02/17
192 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S1-G6, Thompson Fall 2017 USF Tampa, Team S1-G6, Thompson Fall 2017人のメンバー
USFT-THOMPSON-F17S1G6
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 838
